F-350;sen vaihdelaatikko
petekai
Viesti Kirjoittaja petekai »
Heips.
Naapuri pisti tiedustellen, että löytäisinkö tietoa seuraavanlaisesta osasta.
Auto on F-350 7,4 diesel kevyt kuorma-auto -88.
Tämmöseen 4-vaihteinen automaattilaatikko siis hakusassa,
Onko kellään tai mistä alkaisi kysellä moista,
vastauksia odotellen
Pete
Re: F-350;sen vaihdelaatikko
Onko varmasti 7,4 diesel vaiko 6,4 diesel tai 7,3 bensa? Ettei olisi vaan bensakone ja vanhempaa mallia.
The automatic transmission in a Ford F-350 equipped with the 7.4L engine depends on the model year, as Ford did not produce a 7.4L engine; it is likely referring to the
7.3L V8 gas engine, which pairs with different automatic transmissions. Older models (typically pre-2017) with this engine commonly used a 4-speed 4R100 automatic transmission. Newer models (2020 and newer) use the TorqShift 10-speed automatic transmission.
YouTube • 12.7.2024
Engine and transmission pairing
Engine: The 7.4L is a gas engine. The diesel engines offered in the F-350 are the 6.7L Power Stroke V8 Turbo Diesel or a previous 7.3L Power Stroke Turbo Diesel.
Transmission:
Modern F-350s: Use the 10-speed TorqShift automatic transmission, which is specifically engineered to handle the high torque of the diesel engine.
Older F-350s: Models from the 1998-2003 range equipped with the 7.3L diesel engine often came with the 4R100 4-speed automatic transmission.
Important considerations for older models
The 4R100 transmission in older models can have issues, especially if not maintained properly.
Overheating can be a problem, leading to issues like delayed engagement or slipping.
Regular maintenance, including checking the transmission fluid and potentially installing an auxiliary transmission cooler, is crucial for longevity.
This video explains how to change transmission fluid in an older truck:
AI-yhteenveto
A 2008 Ford F-350 with a 7.4 diesel engine is a misnomer; the engine in 2008 F-350 diesel trucks was the 6.4L Power Stroke, which was paired with a 5-speed automatic transmission called the
5R110W TorqShift. The transmission features an electronic control module, lock-up capability, and has a capacity of 19 quarts of MERCON SP fluid.
Engine: The 2008 Ford F-350 diesel was equipped with the 6.4L Power Stroke V8 Turbo Diesel engine, not a 7.4L diesel.
Transmission: The automatic transmission for this model is the 5-speed 5R110W TorqShift.
Transmission specifications
Speeds: 5-speed automatic
Fluid capacity: 19 quarts
Fluid type: MERCON SP
Torque Converter: Included, with an 8-lug mounting and 20 pan bolts
Control: Electronic control module that can adapt to driving conditions
Key features and notes
Stout design: The 5R110W is considered a strong transmission, but it has limits under very high horsepower loads.
Customization: Some parameters can be altered through tuning.
Replacement parts: Some parts, like the transmission cooler and radiator, may require replacement depending on the situation, and some sources say the radiator replacement is required, while others say it is not.
2008-2010 6.4L Ford Powerstroke Transmission – Diesel Power Products
The 2008 Ford 6.4L Powerstroke comes with a new 5-speed Torque Shift transmission, the 5R110W. This transmission has a number of a...
2008 Ford F350 Super Duty Automatic Transmission
Grade Type: Premium. Transmission Fluid Capacity: 19. Screen Resolution: Is300. Reverse Shift Position Quantity: 1. Bell Housing I...
AutoZone.com
2008 Ford F350 Super Duty Super Cab Specs, Features & Options
Table_title: 2008 Ford F350 Super Duty Super Cab Specs, Features & Options Table_content: header: | Save 1 of 8 F350 Super Duty Su...
petekai
"Onko varmasti 7,4 diesel vaiko 6,4 diesel tai 7,3 bensa? Ettei olisi vaan bensakone ja vanhempaa mallia."
Nuo tiedot naapuri antoi. Tapaus ei oo mulle tuttu mitenkään. Oon vaan viestinviejä.
