Ongelmia vaihteiston kanssa
chuckcrowley
Viesti Kirjoittaja chuckcrowley »
Optimize Your Vacuum Cleaners With HEPA Filtration
Since the pandemic, improving the quality of indoor life has unquestionably become one of the most popular needs. If you are looking for ways to better your house’s cleanliness, definitely consider getting the best vacuum in the world with the magical touch called HEPA filters. Ahead, we will explain how this works while recommending to you the best-rated vacuum cleaners with effective HEPA performance.
SO WHAT IS HEPA FILTER?
HEPA stands for high-efficiency particulate air. A HEPA filter has the power of removing 99.97% of most airborne particles with a diameter of 0.3 microns or larger, which means the most harmful and smallest particles and allergens can be eliminated.
People with allergies may notice when they use conventional vacuums, the allergic reaction gets worsen. It is due to the working principle of vacuums without optimized filters. They will suck in debris, pet hair, and dust but cannot pick out tiny irritants like dust mites, pollen, and smoke from the air before releasing it back to the room. In other words, instead of filtering or letting allergens stay in one place, standard vacuums trigger these tiny harmful particles to fly chaotically. Hence, a vacuum cleaner with HEPA filters will be the optimal choice if you have already suffered or are prone to respiratory diseases.
CHOOSING THE BEST VACUUM CLEANER WITH HEPA FILTERS
Since the concept of HEPA is earning higher recognition, lots of unreliable vacuum cleaner sellers are taking advantage of this and tricking consumers into buying vacuum cleaners without genuine HEPA filtration. In order to avoid this trick, try to look for products with certification from trustworthy entities such as the Asthma and Allergy Foundation of America (AAFA). However, even when the manufacturers provide clear and transparent product descriptions, we know you may still feel uneasy. To save you from spending hours on online researching, here are the two best picks that are certified and offer great value based on best vacuum cleaner reviews.
1. Dyson V8 Animal
Dyson never fails to please us with its sleek design, outstanding performance, and continuous innovations. Dyson V8 Animal is one of the most lightweight, flexible yet powerful cordless vacuum cleaners available, which makes cleaning stairs, ceilings, or other tightest areas more fun and efficient. Most importantly, this vacuum is also certified as asthma and allergy friendly by AAFA for its lifetime HEPA filter. Such a well-rounded cleaning buddy you can have for $399.
2. Shark Vertex DuoClean PowerFins
Family with pets or girls with long hair would definitely enjoy this vacuum cleaner due to its dual brush system that can pick up everything at one strike and leave you with no hair warp (The hassle of removing hair from the vacuum’s brush is real!). Besides, the HEPA filtration system of Shark is well-known since it is proven to capture 99.99% of airborne particles. However, the only downside is that its HEPA filter needs replacement now and then, which should not be a concern if you’re totally into its finest HEPA performance. Besides, its price is $349, slightly cheaper than the Dyson model.
CONCLUSION
HEPA filtration is indeed a must-have feature of any The Best Vacuum Cleaners. We hope you find this article helpful and don’t forget to like and share this precious piece of knowledge with your beloved ones.
Viimeksi muokannut chuckcrowley, 13 Kesä 2023 10:41. Yhteensä muokattu 3 kertaa.
NiceMan
Re: Ongelmia vaihteiston kanssa
Viesti Kirjoittaja NiceMan »
Pistäppä sitten auton tiedot merkistä lähtien muuten voi viesti kadota...
Seurannassa tämä.
