Powershift laatikon öljyt
jushi69
Viesti Kirjoittaja jushi69 »
2011 Mondeon ps kyseessä
Paljonko menee öljyä?
Mitä öljyä?
Mondeo 2.0 TDCI Titanium S -11
"Red Devil" -Ikuisuusprojekti-
anon1
Re: Powershift laatikon öljyt
Viesti Kirjoittaja anon1 »
Tilavuus on 6-7 litraa, öljynä käy varmasti Motorcraft Mercon öljyt.
Mondeo -09 2.5T Panther Black
:ford:
It`s my way or no way.
jushi69
http://www.talkford.com/community/topic ... k4-mondeo/
STEP 1: PREPARATION
FLUID CAPACITY: 6 litres.
GETRAG 6DCT450 TRANSMISSION FLUID
Ford specification WSS-M2C936A.
OR
FUCHS part number 4377
FUCHS Titan DCTF
Transmission filter kit.
Temperature of transmission fluid: 35-45 degrees C.
Transmission must not be in limp mode or have DTC's.
Remove air filter housing etc to gain access to filler plug.
Raise car to a convenient height.
Note: CAR MUST BE LEVEL.
Remove undertray (10mm socket)
Place waste container. (About 5-6 litres should come out)
Remove passenger side wheel to gain access to the filter.
Remove two nuts and three screws and clamp the plastic guard
out of the way.
Engine running, brake pedal applied, select all gear positions
for 20 seconds each. Return to PARK.
STEP 2: DRAIN THE OLD FLUID
Engine off.
There are 3 drain plugs before 02/2009, 2 drain plugs after.
Remove all the 8mm hex socket drain plugs.
After the fluid has drained replace the drain plugs.
Unlock and remove the filter.
Note: The filter housing has a plastic locking clip, a small
plastic wedge is handy to hold it open.
STEP 3: FILL WITH FRESH FLUID
Prime the new filter with fluid (about 0.1 litres) and install.
Fill transmission with 5.5 litres of fluid.
Install the filler plug.
STEP 4: LEVEL ADJUSTMENT
Remove the level check plug.
A two-foot long extension with a universal joint makes it easy.
Allow fluid to drain until it begins to drip.
Note: THE FLUID THAT ESCAPES DIRECTLY AFTER
THE FLUID LEVEL CHECK HOLE IS OPENED
IS NOT AN INDICATION OF A CORRECT FLUID LEVEL.
FLUID MUST BE ADDED THROUGH THE FILLER OPENING
WITH THE LEVEL CHECK HOLE OPEN UNTIL THE FLUID AGAIN
RUNS OUT AT THE LEVEL CHECK HOLE, AS FOLLOWS:
Top up via filler hole until fluid flows again
through the level check hole, allow to drain again
Install level check plug and filler plugs.
Put the rest back together and the job is done.
Tommonen kiva ohje löyty... Eli 6l on oikee määrä ja fuchs titan dctf öljyks
Löyty vaihto videonakin :shock:
https://youtu.be/Fy0TVRWjFfg
Suodatin ja öljy tilattu sit vaan ootellaan et pääsee vaihtaa.
TomGalaxi
Viesti Kirjoittaja TomGalaxi »
Pitääkö nuo Fuchs Titanit Saksasta ostaa? Entä muita hyväksyttyjä merkkejä olemassa? Motonet olisi kiva ostopaikka.
-00 Chrysler 300M 2.7 Cinnamon Glaze Metallic
-12 Ford Galaxy Ghia 2.0 TDCi people carrier Panther Black
Castrolilla on öljy nimeltä Transmax Dual. En siitä muuta tiedä, kuin että Castrol on ollut yleensä aika hyvin selvillä, mitä Fordiin kannattaa laittaa. Ei taida Motonetistä tuota löytyä. Oliskohan RedLinellä sopivaa?
TomGalaxi
Sitten on nuita ulkomailta tilattavia tosiaan mm. Fuchs, Amsoil, Red Line kanssa, kai sitä Suomestakin saa, Forssasta löytyy Ravenol, Usparts myy Gulf 2500 DCT:tä. Moparilla on niin hyvä tuo http://www.centerforqa.com/chrysler-brands/ Eikö kukaan ole Fordille, tai siis DCT450:lle vastaavaa tehnyt?
Ei tosin ole kauhean paha Saksasta Fuchs Titan 130€ 20l kotiovelle. Ravenol olisi Vorsassa 12l 150€. Castrol ja Motorcraft on minun lompakolle liian kalliita. Litrahinnat 30€ luokkaa. :shock:
TomGalaxi
Marmoritiskiltä kysyin piruuttani laatikkoöljyn hintaa, niin 32€ litra oli prkl. 157€ viisi litraa. :ford:
TomGalaxi
Motul DCT 6 litraa harakiri-liikkeestä omasta kylästä 108€. Ei paha. Motonetistä EN uskaltanut Comma öljyjä ostaa. Aisin laatikolle vaan suosittelivat.
NiceMan
Viesti Kirjoittaja NiceMan »
Itse ostin Motonetin poistosta 11€/purkki Redlinen öljyä laatikkoon, on toiminut erittäin hyvin tosin ajettu vasta 15tkm mutta vielä vaihtaa jämäkästi. Itse vaihtohan ei ole iso homma.
MrField
Viesti Kirjoittaja MrField »
Ihan kohtuuhintaista tämäkin. Nyt ilmeisesti tarjoushinta 13,90€ / litra.
https://www.fixusnet.fi/fin/vaihteistooljy-p-608793-0/
Ford S-Max 2.0 TDCI Powersift 2011
Ford Focus Estate 1.6 A 2004
