Mondeo mk3 preface keskikonsoli
madonion
Viesti Kirjoittaja madonion »
Eli miten ton saa irti? Pohjassa kaks ruuvia ja missä muualla? Onko hätävilkkujen/ikkunanlämmitys nappien takan ruuvit? Muualla?
Wizurd
Re: Mondeo mk3 preface keskikonsoli
Viesti Kirjoittaja Wizurd »
madonion kirjoitti:Eli miten ton saa irti? Pohjassa kaks ruuvia ja missä muualla? Onko hätävilkkujen/ikkunanlämmitys nappien takan ruuvit? Muualla?
jos englanti taipuu niin näin...
"either way you will need to remove the side panels in the footwells first
then the centre trim around the gear stick
then the rest of the panel that is around the gear stick
and the radio
and the panel that contains the heated screen and hazard light buttons (this pulled out but it is in there very tight so don't bend it beyond anything mroe than a few mm as it can snap)
and finally the radio needs to come out as well
this will allow you to access all the screws that you need to access in order to remove the centre console
be aware that the heater controls screw into the back of the panel so cannot be removed wihtout the panel being removed first
it's easy enough if you know what you are doing and i've had mine apart in about 15 minutes all in, but be aware also that there are a few screws which will not be as visable as you would think and that there are other places where you may think there are screws but there aren't, just pins and push in clips"
Petervonpah
Ylläpitäjä
Viesti Kirjoittaja Petervonpah »
noh ohan se ohje toikin :) . mut kyl näin suomeksi sanotusti siel on :) sivulta jutut irti ja sit vaihevivun kehikko irti niin pitäs sit näkyä kaks ristipäätä noiden napien alapuolelle. vai olikos nappien takana :) noh mut kumminkin
