Explorer 95-01 etuakselin arvoja
Fuller
Viesti Kirjoittaja Fuller »
Tässä Dana 35 etuakselin ja tasauspyörästön arvot, englanninkielellä
FRONT DRIVE AXLE/DIFFERENTIAL — DANA 35
General Specifications
Housing Spreader Adapter bolt
thread engagement 12.7 mm
Maximum spread of
differential housing
0.381 mm
Ring gear backlash 0.13-0.20 mm
Maximum backlash variation
between points checked 0.05 mm
Sealant
Ford Black Silicone Rubber F4AZ-19562-B
Ford spec. WSE-M4G-323-A1
Lubricant
Motorcraft SAE 80W90 XL-80W90-QL Thermally Stable 4x4 Axle Lubricant
Ford spec. WSP-M2C-197-A
Capacity
Front axle 1.54 L
Lubricant level 9.56 mm below bottom of axle cover filler hole
Torque Specifications
Front axle retainer bracket bolt 106 Nm
Ring gear bolt 109 Nm
Differential bearing cap bolt 61 Nm
Differential housing cover bolts 22 Nm
Axle to frame bolt 66 Nm
Pinion bearing preload (new pinion bearings) 1.7 - 3.4 Nm
Pinion bearing preload (original pinion bearings) (a)
Universal joint spider retainer bolt 19 Nm
Brake caliper guide pin bolt 33 Nm
Tie-rod nut 91 Nm
Upper ball joint pinch bolt 48 Nm
(a) - The reading must be 0.56 Nm more than the initial reading taken during disassembly.
