Comprehensive Component Monitor CCM ongelma
Lähetetty: 08 Syys 2014 18:17
Oma OBD-mittari näyttää: Comprehensive Component Monitor ei ole "valmis"
kaikki muut on päästömittaukseen vaadittavat kohdat on o.k . paitsi tuo CCM.
Ei vikakoodeja , sehän tässä ihmetyttää jos jotain häikkää olisi, niinkuin ilmeisesti on niin valo pitäisi syttyä kojetauluun tai ainakin vika-koodi löytyä.
"Comprehensive Component Monitor
The Comprehensive Component Monitor (CCM) is an on-board strategy designed to monitor for failures in emission-related electronic components and circuits that provide input or output signals to the PCM. These are systems or devices that are not exclusively monitored by another monitor system. If the PCM detects that an input or output signal is inoperative due to an out-of-range value, open circuit or if an on-board rationality or functionality check fails, the PCM will set a code in memory and activate the MIL."
"Continuous: These monitors run all the time as long as the key is turned on and/or the engine is running. There are three continuous monitors that every OBDII equipped vehicle has, they are the Comprehensive Component Monitor, The Fuel Monitor and the Misfire Monitor."
http://i57.tinypic.com/bje24k.jpg
Ford Fusion 2009 1.6 duratec bensa
