Turvavyön piippari pois käytöstä Mondeo -03
temezii
Viesti Kirjoittaja temezii »
Mitenkäs sen muistuttimen saa pois?
Jostain aikoinaan luin mutta enää en löytänyt sivua
lamppu
Re: Turvavyön piippari pois käytöstä Mondeo -03
Viesti Kirjoittaja lamppu »
Muistaakseni joutu ottaa lisäks jonkun sulakkeen pois liittyen "ajovaloautomatiikkaan".
Mondeo ST220 *panther black*
temezii
En vielä ainakaan onnistunut noilla enkku ohjeilla saamaan pois huutajaa.
Mahtaakohan johtua siitä kun on ajovaloautomatiikka?
lamppu
Ford TIS:stä lainattu:
"TECHNICAL SERVICE BULLETIN No.82/2002
Car and Light/Medium Commercial 29.08.2002
Section: 501 - 20A
Model: 2001 Mondeo built from 04.02.2002 (build code 2Y) onwards
Markets: All
Subject: Seatbelt 'beltminder' deactivation
Summary
Permanent seatbelt 'beltminder' deactivation instructions can no longer be included in user manuals from 2003 MY (EuroNCAP requirement). This bulletin describes the operation required to deactivate/activate beltminder.
Service Instructions
'Beltminder' Deactivation/Activation
Sweden, Norway, Finland and Denmark only
Note:
On vehicles in Sweden, Norway, Finland or Denmark with daytime running lamps, fuse F84 should be removed for this procedure (located in central junction box). Upon completion the fuse should be installed.
All markets
Note:
Do NOT start the engine.
1. Turn the ignition switch to position II.
Note:
Wait until the air bag abd beltminder warning lamps have extinguished (in markets equipped with seat belt warning, this can take up to 1-2 minutes).
Note:
The next 3 steps must be completed within 60 seconds. Failure to do so will result in having to repeat the procedure.
Note:
Care must be taken to make sure the seat belt has been fully engaged and disengaged properly.
2. Slowly buckle then unbuckle the seat belt 3 times, ending with the seat belt unbuckled.
3. Turn the headlamps on and then off again.
Note:
This will deactivate beltminder if currently activated or activate beltminder if currently deactivated.
4. Slowly buckle then unbuckle the seat belt 3 times, ending with the seat belt unbuckled.
Vehicles built up to 18.07.2002 (build code 2M)
5. The beltminder warning lamp will illuminate for 1 minute.
l Slowly buckle then unbuckle the seat belt 1 time during illumination.
All vehicles
The deactivation/activation procedure is confirmed by the beltminder warning lamp illuminating for 3 seconds on vehicles built from 04.02.2002 to 18.07.2002. On vehicles built from 19.07.2002 onwards, the deactivation/activation procedure is confirmed by the beltminder warning lamp illuminating 3 times in 3 seconds."
Muistaakseni toi sulakkeen numero ei ollut ihan oikea tossa, mutta lähellä oleva valoihin liittyvän kun otti irti niin homma alko toimimaan..
