Kiristysmomentit
calaxies
Kiristysmomentit
Viesti Kirjoittaja calaxies »
Hei. Onko kellään tietoa Ford mondeo 2007 2.0 bensa duratec, Kiertokankien ja runkolaakeripukkien kiristysmomentteja??? . Ei löydy mistään.
Re: Kiristysmomentit
Kiertokanget 29Nm + 90°
Torque setting 29Nm then +90deg.
Ford Duratec HE I4 16v (4 cylinder)
https://www.burtonpower.com/std-con-rod ... fd245.html
Runkolaakeripukit yms.
Main bearing cap bolts tightening procedure and torque specs:
ELASTIC REGION TIGHTENING BOLT (BOLT STEM LENGTH 104 mm)
Step 1: 3-7 Nm; 30.6-71.3 kg·cm; 26.6—61.9 in·lb
Step 2: 23-27 Nm; 2.4-2.7 kg·m; 17—19.9 ft·lb
Step 3: 38—42 Nm; 3.9-4.2 kg·m; 28.1—30.9 ft·lb
Step 4: Loosen all the bolts
Step 5: 3-7 Nm; 30.6-71.3 kg·cm; 26.6—61.9 in·lb
Step 6: 18-22 Nm; 1.9-2.2 kg·m; 13.3—16.2 ft·lb
Step 7: Turn all bolts 90°
PLASTIC REGION TIGHTENING BOLT (BOLT STEM LENGTH 110 mm)
Step 1: 44-46 Nm; 4.5-4.6 kg·cm; 32.5—33.9 in·lb
Step 2: Turn all bolts 175°-185°
After securing bearing cap bolts, make sure the crankshaft turns smoothly by hand.
Connecting rod bearing bolts
Step 1: 26-32 Nm; 2.7-3.2 kg·m; 19.2—23.6 ft·lb
Step 2: Turn all bolts 80°-100°
https://www.engine-specs.net/mazda/ford ... da-lf.html
