2.0 TDCi 140 HP -> 163 HP
Dweon
Viesti Kirjoittaja Dweon »
Moronta!
Uusi innokas Ford-mies ilmoittautuu!
Tässä tuli intternetin foorumeilla vastaan, että uudempi 2.0 TDCi euro 5 -kone on mahdollista Fordin omalla softalla päivittää 140HP -> 163HP, jos löytyy ELM327 sekä IDS/VCM.
Ford Etisin mukaan omassa kulkineessa löytyy foorumin mainitsema 2.0L Duratorq CR TC (140PS) - DW10C
Löytyisköhän moista kompinaatiota Oulusta, olisi mielenkiintoista testata... :twisted:
If you are the lucky owner of a 2011 (Facelift) 2.0 TDCi and also have an ELM327 and IDS/VCM interface then you can upgrade your 140 BHP to 163 BHP with Fords own FW.
Actually the FW for the 140 & 163 is the same and just a couple of bits tell the ECU that is has to use the maps for the 140 resp 163 engine.
First you need Elmconfig and a modified ELM327 interface (google this or check Mondeo MK4 electrics subforum for links)
Read you config from BCM and save a copy on you computer.
Then change the parameter for the Engine (page 2 elmconfig Central Configuration tab) to 2.0 I4 150PS Diesel DW10C Stage V , this is 1 step above the 140 PS engine.
Write back the central config to both IPC and BCM (ignore all flashing lights and errors on dash) with the new engine parameter set.
Fire up IDS och start new session.
After antering all needed data on the first page under the menu where you perform service function you will find possibility to do service functions for the PCM.
This is the same place where you can reset DPF counter , EGR , MAF and so on...
Almost at the bottom of this page is a function called write Central config to PCM... run this and you will now have a 163 PS car :)
Do a faultcode scan of all modules and reset all DTC:s
You maybe get a IPC dtc saying central config missing , just do a read of the config with IDS and write it back as sometimes elmconfig can corrupt the config in the IPC but this will be sorted by IDS.
Deippa
Re: 2.0 TDCi 140 HP -> 163 HP
Viesti Kirjoittaja Deippa »
Täältä löytyy lisätietoa: http://www.talkford.com/community/topic ... onfig-ids/
Elmconfigilla ja lukijalla pitäs siis onnistua kotioloissa. Ei omakohtasta kokemusta.
S-MAX -10 TDCI 140hv
Dweon
Tuolta juuri kopsasin alkupostauksessa olleen quoten.
Kokemusta on enemmän VAG konsernin kulkijoista, ja niiden konffauksesta, minkä takia olisi mukava säätää kokeneemman kanssa.
Näyttää internet olevan täynnä ELM327 -piuhoja, mutta tae niiden toimimisesta on sitten eri asia.
Onko suosituksia hyväksi havaitusta kaapelista? Selasin vikakoodi -ketjua ja siellä oli "tämä ei toimi" tyyppisiä vastauksia.
Deippa
Tämmösin tilasin itelle ja ainakin se yksilö toimii tietokoneen kans: http://www.ebay.com/itm/Ford-USB-Super- ... Sw~OdVXG5j
ja tämä toimii puhelimen kans: http://www.ebay.com/itm/SALE-Orange-Car ... SwU-pXtnls
Dweon
Asiapa kunnossa, tattis.
Ymmärsinkö oikein, että pelkästään yhteensopiva kaapeli + ELMconfig riittää? Pakko vääntää rautalangasta, kun internetin ihmemaassa on moninaisia ohjeita. :roll:
brainsurgery
Viesti Kirjoittaja brainsurgery »
Alkaako selvitä vai pitääkö kiikuttaa auto AJ Techille? :)
Mondeo MK4.5 2.0TDCI 103kW
brainsurgery
Täältä löytyy jotkut ohjeet miten saman saa tehtyä Asbuiltilla (en tiedä mikä se on ja miten se toimii).
http://www.ucdsys.ru/forum/viewtopic.ph ... t=15#p5790
Dweon
Tuo mahtaa olla UCDS -kaapelin softa. Venäläinen multipurpose -kaapeli, jolla lienee ajaa samat asiat kuin IDS:llä?
Kyllä tässä jo sekin kävisi mielessä, että rehellisesti kävelee setelinipun kanssa vain softapajan tiskille ja tekee tämän kunnolla. :lol:
C344
Viesti Kirjoittaja C344 »
Tuo taitaisi onnistua IDS:llä käyttäen special funktiota 60274 - IDENT_LAUNCH_CCC_ENGINEERING_APP, jolla pääsee tuon engine parametrin muuttamaan.
Dweon
Hello,
If so, it can be done in FORScan too. You need to run Central Configuration and change engine type to the one you need, then run PCM learning procedure. If something doesn't work/missing, please feel free to contact us.
Regards,
FORScan Team
:roll:
brainsurgery
Dweon kirjoitti:
:roll:
Joko kokeilit? :)
-kuga-
Viesti Kirjoittaja -kuga- »
Onko joku kokeillut tätä ja saanut toimimaan..? :roll:
jaketson
Viesti Kirjoittaja jaketson »
14 vuoden galaxyyn yritin elmconfigilla tehdä muutoksen, mutta ohjeen mukaan tekemällä pcm moduuliin ei pysty tekemään kirjoitusta kun ohjelmasta ei löydy sellaista kohtaa.
Oulu
-kuga-
Täytyisikö ohjelmasta olla tuo "Extended license" versio..?
http://www.forscan.org/comparsion.html
En ole vielä ehtinyt testailemaan, koska sain piuhankin vasta ihan äskettäin... :roll:
jaketson
Mitenhän sen extended lisenssin saa? Luulen kuitenkin että pitää kirjoittaa ids:ssällä. Soittelen huomenna wetterille/sah autohuollolle alkaisiko ne päivittämään pcm moduulin.
Oulu
jaketson
Ei oulun liikkeet olleet perillä asiasta niin jätin sikseen, mutta ucds kaapelilla sain muutoksen tehtyä. Nyt näyttää laskettu vääntö n. 370nm.
Oulu
